Somehow, I had my 3 fuses blow on them. Check there first to see if they are any good. I had one that would run the drain/fill, so I pulled that fuse and plugged it into the others and if they didn't work, then I disconnected that pump and run electric to it externally. (D battery with a +/- wire should be enough power to lightly spin the motor)...
On the pump that didn't spin, I was able to turn the fin (had access to it) and then it worked, so my pumps are back in working condition again...
2004 Supra Launch 22 SSV
5.7L Indmar Assault
"One More Hour"
