Bought a 2006 Supra 22SSV last fall, awesome boat. Radio worked fine but would power cycle if a big wake was it hard.. Shook it off to be no big issue. This year, head unit had to be replaced due to CD door issues. Replaced with exact unit and wiring harnesses were exact fit, no modifications or wiring changes were made. Hard bass from the subs initially power cycled the unit and issues continued to progress. Power cycles are now often and does not work at all sometimes. When is working, any use of another accessory such as ballast pumps, bilge pump or wake plate operation causes power cycle.. Often it will just get into an infinite loop of power cycles. Cannot find any loose wires or bad connectors.. Tired of using iPhone for tunes...thoughts?
