Page 1 of 2 12 LastLast
Results 1 to 10 of 14
    Sep 2010
    Bend Oregon
    Default Surfing Saltare Goofyfoot
    So I installed my "prototype" surf gate a few days ago, and my friend took a video of it I thought i would share. He is definitely no Spielberg, in fact the video is a neck breaker, he must have turned the camera a few times during filming! Haaha! Along with that we went into a shady area half way through and it gets a little dark. So if you can stomach it check it out!
    Regardless, the surf wake drastically improved with the use of the wake gate, I was able to surf 12-15 feet back, and in the begining I was able to recover from over 15ft back which has neeeever happened before, but there are a few changes I could make to improve it further going forward. Now lets see if I can upload the video, I had to post it to Youtube to do so.
    Aug 2010
    Anderson SC
    What the H%$l is he thinking with the camera!??!?!?!?!?
    Looks like good fun
    Kevin Allen
    Sep 2010
    Bend Oregon
    Default Questionable video work!
    Quote Originally Posted by Kma4444 View Post
    Looks like good fun
    Yeah I must agree, the video was a little tough to watch, shipmate must have had a few to many! I think at one point I got some vertigo watching it!! However, my wife was able to fix it being a computer Guru and using one of her programs so if I can I will post it here and drop the old one, make it a little more palatable. Its actually interesting to watch for me seeing my self surf, the little things like shifting my weight back or forth to change position on the wake, or moving my feet around to also change the direction of the board, all pretty much subconsciously... Kinda a throw back to my Doheny days and learning to surf in the Pacific Ocean, miss those days!
    Apr 2015
    How much ballast are you running in your saltare
    Sep 2010
    Bend Oregon
    Quote Originally Posted by Smitty40s View Post
    Sorry been away doing other stuff for a bit. I believe this day I was running 300 rear locker, I have 800 surf side, and two 250 on the rear bench seat. The trick this day was I had tried out my DIY "wake shaper" and it made a huge difference. I molded it much the same as CornRickey's and I was able to run way less weight, the wave was a lot cleaner and longer, I could recover form 15+ feet back, good day!
    Apr 2010
    Coppell, Texas
    Hi- ok so I have a Saltare- and we totally want to take up wake surfing this season. Can you help me?
    * what kind of, how much weight (which side) and where did you install your fat sacks?
    *whats a wake gate? Where did you get it? and what size for saltare?
    * what size board do we need- for kids 9-19? And me- 230 lbs/ 5'11?
    Sorry for so many questions but you have it figured out for a Saltare and I'm racking my nuts trying to search the web for specifications for this boat.. Any help would be very greatly appreciated brada-!!
    Jun 2014
    Lexington, KY
    Just came to this thread to add what I have learned. I have been playing with my Saltare dialing in the surf wake.
    I am currently running a 450lb bag in the rear locker, a 550lb bag in the floor in the space behind the motor box (conforming to the trapezoidal shape, so probably not fully filling), and an old Launch Pad "couch" on the surf size (in this case starboard) that I think weight about 800-1000lb. I have also added a "little bit better than home made" (I have a $10M/year machine shop at my disposal) wake shaping device to the opposite side of the swim platform to help clean things up. The wake was respectable with weight alone when set up on the port side of the boat, but it was really washed out on the starboard side before the wake shaper.
    My wake shaper design:
    I'm playing with that design keeping the idea of marketing it on a small scale in mind. The idea is to give it enough degrees of freedom to accommodate a wide range of old boats. it does look like Mission Boat Gear (http://www.missionboatgear.com/) is well ahead of me, and that is a good thing, because I really don't want to mess with this much further than my own interests.
    Here is a relatively crappy cell phone video from last night:
    Please excuse the mid ride pant's check
    Korey Morris -
    Sold to Arkansas: 1986 Supra Saltare
    Current: 2018 Moomba Craz
    Jun 2014
    Lexington, KY
    Korey Morris -
    Sep 2004
    Hudson, WI
    You guys are having better luck than I've ever had with the goofy wave - but it's good to know that it's possible with just a little more weight!
    Korey -- When you going to send me one of those gates for me to try out? )
    Jun 2014
    Lexington, KY
    When I pulled the gate off to head home last night I hopped up to speed just to see what it looked like with all other conditions identical (well, I guess with +1 person in the boat since no one was riding), and the wake was complete garbage. I'm astonished at how well the first iteration of my gate worked!
    After watching how the water flowed around the plate from behind the boat, I'm more interested in playing with a plate that is more perpendicular to the flow of the water. The 2014 Moomba Mojo that I spent a ton of time behind last summer had their first "Flow" system that was very simple, but affective:
    Korey Morris -
