Results 1 to 3 of 3
Thread: Bigger Pump
    Default Bigger Pump
    I have a 2013 SA 450. I'm adding a couple more bags for weighting for surfing to it. I was curious if there are any recommended pumps that I should replace my factory pump with in order to minimize the wait time when filling the tanks or when I need to switch sides. Any recommendations are appreciated!
    Any one have any idea as to what the base pump(s) that are installed in the boat are?
    Thanks!
    Brady
    Apr 2012
    Lake Wylie NC Area
    I think you would be better off to add supplementary pumps, rather then attempting an upgrade.
    Michael
    Mikes Liquid Audio
    Jun 2012
    Knoxville TN
    Default Bigger Pump
    +1
    Adding new bags on top? Add a new pump. One new hole in the bottom could be routed to either bag by the use of Y-valve. Save some bucks by not purchasing 2 new pumps. I guessing you only weigh one side for surfing?
    http://www.wakemakers.com/bosworth-y-valve.html
    Mark
    Sent from my iPad using Tapatalk
    2018 Supra SL400
Tags for this Thread
