So when I had my floor and stringers replaced a few years ago, we ignored the fact that I had some rot in the transom. There are 3 wooden blocks located in the transom where the 3 swim platform mounts are located. The one in the center is good, but the two outboard blocks are rotten. I've tried using CPES from the Rot Dr. But there just isn't enough wood there to make a difference. So I'm thinking about making the repair this winter. If I remove the fuel tank (again), then I think I can gain enough access to cut out the fiberglass and remaining wood from the inside with a cutoff wheel. Then if I grind and clean the surface, I should be able to replace with new wood and re-glass the inside - right?
Any thoughts on this, ideas . . .
What materials do I need to adhere the blocks to the transom and then glass over?
