Results 1 to 10 of 12
    NC
    Default What alternator to upgrade to
    I have a supra with a indmar assault 325. My altenator is out and I need to replace it. Anybody know the part number for a direct replacement. It's has the 70 amp one now and I would like to go up to the 90 or bigger with kith changing anything else. I think the 90 is a plug and play but can't find the part number. attachment.jpg
    NC
    attachment1.jpgone more
    NC
    Local dealership told me I would have to swap out all the pulleys to upgrade to the 90. Can anybody confirm this ????
    and
    If you look at the one on the bottom of this page http://www.skidim.com/products.asp?dept=1174 I think it will work for my boat but I'm not sure. If I could find the part number for the kit I could get it for a discount from my father inlaw but the website doesn't give a lot of information.
    its a 2006 24v sunsport
    Sep 2004
    Hudson, WI
    I believe that a 11si would be the 90 or 95amp version, but all of them that I see have the 6-groove belt pulley on them. Shouldn't be that hard to pull off your existing pulley and install it on the new alt.
    I'm 90% sure that the 10si mounting feet are the same and that the case is only a HAIR larger. They come in a 160a version from dbelectrical that isn't much more and mine has worked great for 8 years now (knock on wood.)
    May 2008
    Mt Juliet, TN
    Engine serial number?
    1987 Supra Saltare
    PCM 454
    NC
    Here you go
