AMPS warning light stays on?
So I've had my '88 Sunsport out three times so far this Spring without any issues, aside from the "AMPS" warning light on the dash staying on. It starts right up every time and is showing ~13 volts charging on the dash. Before going out this past Sunday, I checked both batteries (deep cycle) which are running off a Perko switch, and both showed 12.70 volts, so they are definitely being charged. Ran the boat for 8 hours Sunday and the light was on the whole time, but experienced no issues. Played music the whole time, anchored for a bit with just music on, and she started right back up. Could the light just be stuck on? What's the best way to check amperage on the batteries to see if I might need to replace one or both?
'88 Sunsport, 2250lbs ballast, automated surf system, home made surf exhaust, surf flap, ACME 913, Krypt 6.5 HLCD's, Perfect Pass Stargazer
2007 Centurion Typhoon to be upgraded this winter!
