Page 9 of 13 FirstFirst ... 7891011 ... LastLast
Results 81 to 90 of 123
  1. #81
    Jul 2011
    fort worth , tx
    Ok I got the heads dialed in all within
    .020 of 1.900 installed height on the springs , no coil bind and seal to retainer is .200 so I bolted the heads up and installed the roller lifters and spider hold down bracket with dog bones , rockers should be here Monday to check for push rod length and then order push rods , I also decided to buy a new rudder assy because mine is worn past and is leaking , so more to come on that and I listed in another thread if you would like to follow ,
    Here are some pics of what is going to look like and progress !
  2. #82
    Jul 2011
    fort worth , tx
  3. #83
    Jul 2011
    fort worth , tx
  4. #84
    Jul 2011
    fort worth , tx
    Ok , setting up heads is a real art form , I have been setting up rocker arm geometry and found the valves that came with these heads are to long , that causing my sweep
    Pattern on valve tip to be wrong . .050 thou in middle of tip is what I'm shooting for . So I'm waiting on valves to. Come in then I can finally assemble .
  5. #85
    Sep 2010
    Collegedale, TN
    I'm glad you're finding this out in advance. Once this get puts together you'll need to post a video so we can hear it run.
    1986 Saltare
  6. #86
    Jul 2011
    fort worth , tx
    Believe me brother I've been itching to hear it . But I gotta follow the order by the book so I know it's right . And the engine alignment shouldn't be as bad as I thought . So maybe next weekend will see
  7. #87
    Jul 2011
    fort worth , tx
    Progress ! I finally figured out the push rod length and getting the wear pattern,
    Anybody that is thinking of getting flotek heads , think twice ! I have been at this BS for 1 month , they even sent me different valves ! My problem was the valve centerline to sweep on valve tip was way off cause the rockers I was using ! So finally they only will accept full trunion roller rockers , nothing else . Speedway motors hooked me up but they are not cheap ! $300 . Also I got the dizzy in today and the AN fuel lines , ordered my 7.500 push rods for .060 sweep and I'm gonna push to have this thing started next weekend and possibly put it in the boat !
  8. #88
    Jul 2011
    fort worth , tx
    Got the push rods in and set all the rockers up , should be able to start it up this weekend . I'll post a video and pics for progress !!!
  9. #89
    Jul 2011
    fort worth , tx
  10. #90
    Sep 2010
    Collegedale, TN
    Wow. This is going to be too pretty to run! Are you going to dyne this before it goes back in?
    1986 Saltare
