Originally Posted by
codemonkey82
I also need to know if I should remove all thru-hull and thru-transom bolts and reseal with 5200 or is it a 'if it ain't leaking don't touch it' kind of a thing? The goal of this rebuild is to never have to tear this far into this boat again.
I would. Those backing blocks look like they've been done by a previous owner and look to be untreated wood? You'll want to use plastic or aluminum plates so that you don't need to worry about them again. I'd use nylick nuts and 4200 (5200 is PERMANENT!)
