Results 1 to 4 of 4
    Mar 2012
    White Rock BC Canada
    Default 1992 Supra Comp TS6M Transmission Oil Cooler
    I'm going to take advantage of the great success I've had in the past on the supra forum. I fired up my boat last week and water was spraying out of my transmission oil cooler, the bottom half is completely cracked. It's silver (I will post a photo when I get home tonight) with two oil hose connectors and two water hose connectors. Also, some how I've lost the 3 pins that hold up my swim platform? My question is simple, where is the best place to find replacement parts for a boat this old?
    Some simple google searches don't come up with much? Thank you!
    Jun 2013
    Syracuse NY
    Skidm has the cooler. But any generic cooler will work as long as it's the same size. For the pins you can get them at any fastner company. You'll want stainless
    1995 supra labrisa
    Pro boss gt40
    GPS Ridesteady
    Mar 2012
    Nice! thank you very much, I think I see the oil cooler already, I'll double check the fitting size when I get home.
    Aug 2010
    Oyama, B C , Canada
    Replace the pins with long threaded bolts and nylock nuts.
    They wont get "lost" that way.
    Changed mine out four years ago --end of problem
