3 Liquid Force board/binding sets for sale
I have 3 board and binding sets for sale, as follows...
The Watson wakeboard is a 142 and described below. The bindings are 10-11 and described below. This package retails for $650. I am asking $300 OBO.
2011 Liquid Force Watson Classic 142
If you're looking for that little extra something to get you over the hump and take your riding to that next level, this is the board for you! The Watson Classic is just that, a true classic. It's that beautiful car that you see driving around town on Sunday morning. It performs like a champ and always puts a smile on your face. This board has a snappy response and super smooth feeling below your feet. Step your game up with the Watson Classic.
Aggressive, Three-Stage Rocker - Hard hitting pop that boosts you straight up. Truly compliments the wake to wake rider.
Spiral "V" Double Concave Mid-Section - Breaks the water for soft landings, initiates and rolls into turns quicker and easier.
Lifted Variable Edge Rail - Rounded rail in the center for a forgiving feel, sharp rail at the tail for edge control and response.
Quad Vented Channels - Placed between the molded fins to vent water through the tip. The water skips over these channels to give lift without disrupting water flow around the fins. Helps generate speed while keeping you pointed in the right direction.
Crisp Molded-In Fins - More defined, shorter base molded-in side fins provide positive control without catching too soon. Fast, loose and have the holding power to carve.
Length: 142.1 cm (55.94 in)
Mid Width: 17.52 in (44.5 cm)
Rocker: 2.52 in (6.4 cm)
Rocker Type: Aggressive three-stage
Skill Level: Intermediate/Advanced
Construction: Polyurethane foam core wrapped in glass
Fin Configuration: Three on each end. One XLR 1.0" center fin and two molded-in side fins. 1.0" XLC fin also included.
Rider Weight: 160 lbs (73 kg) and up
Stance Width: 23 in (58.42 cm) to 27 in (68.58 cm)
MSRP: $349.99 USD
2011 Liquid Force Vantage OT
The 2011 Vantage Open Toe Binding has the responsive ride quality advance riders demand. With the Flex Level 6-8 The Vantage OT Binding is perfect for big boosting and clean carving. This binding has just the right combination of flexibility and support you need to hammer that new trick. Meet your new BFF, the 2011 Vantage OT.
Flex Level 6-8
IP6 Chassis
Integrated Lock Plate
Impact EVA
EVA footbed
Contact Liner
Articulating Cuff
Velcro Zone System
Sizes: 6-8, 8-9, 9-10, 10-11, 11-12, 12-13+
MSRP: $299.99 USD
The Shane wakeboard is a 134 and described below. The bindings are 5-8 and described below. This package retails for $589. I am asking $275 OBO.
2010 Liquid Force Shane 134 Wakeboard
The Shane is the perfect combination of fast aggressive edging and a fun unmatched pop. If you're looking to take your riding to the highest levels, the Shane is the perfect 3-stage ticket to fun!
Product Specs:
Double to Triple Concave Hull - D-I-S-C hull through center, deepens underfoot, into triple out the tail - DISC for softening impact and maintaining speed - Deep double for precise sweet spot lift under your feet - Triple concave with BIG center single for ollie power and pop.
Winged scalloped tail outline - full shape with release at rail wings - Allows rider to shorten the arc of his turn off the wing for slaying.
Molded in Warped long base side fins - Smooth water flow, superior hold, minimum drag.
Shallow canted inside fins placed at edge of center tip concave - Acts as extension of concave to maximize the thrust through center.
Low volume rails with thinned out tip section - Faster on edge with more hold - Low swing weight and tip flex.
Lifted Variable edge rails - Slight bevel, rounded to sharp through length of rail.
Aggressive, 3-stage Rocker - Gives the rider the highest trajectory arc off the wake for a straight-up pop. Coupled with the deep single concave between the center set of fins, the new Shane has unmatched ollie power.
Shallow Scalloped Tail - Full tip area working with the large concave exiting through the center.
Length (cm): 134.3 cm
Width (cm): 42.5 cm
Rocker (cm): 6.2 cm
Length (in): 52.8 in.
Width (in): 16.8 in.
Rocker (in): 2.4 in.
Rocker Type: 3 Stage Aggressive
Stance Range (cm): 53.3 - 63.5 cm
Stance Range (in): 21.0 - 25.0 in
Rider Weight (lbs): 90 - 170 lbs
Rider Weight (kg): 40 - 77+ kg
Center Fin: Molded in Set Warped Cants/Small
Side Fins: Warped/Long base
List Price: $379.99
2010 Liquid Force Domain Wakeboard Binding
If you're looking for an entry to mid level wakeboard binding with more support than your standard entry level setup, the Domain wakeboard binding should be your #1 choice.
Features:
IP Chassis...New for 2010! - Reliable, hassle-free adjustment. . . Angle Locks hold strong and allow for easier stance adjustment than ever before.
Pillow Top Liner - Extra soft padding where you need it most. Eliminates shin and calf discomfort from those marathon sessions.
Inside Comfort Gusset on Toe Piece - Medial comfort gusset allows toe piece to lift while foot easily slides into boot, and still provides extra lateral support on hard landings.
Velcro Tightening Straps - No Laces! Our most convenient closure system..allows for more adjustability of fit throughout the different regions of any foot.
Integrated Heel Piece - Heel piece is integrated into overlay for easier entry and more comfortable fit when in boot.
Multi-Fit Design (5-8, 8-12, 12-15) - Specially designed tongue allows for proper fit on the widest range of foot sizes possible. Share the boots with a family member or your friends.
List Price: $209.99
The Jett wakeboard is a 136 and described below. The bindings are 9-10 and described below. This package retails for $599. I am asking $275 OBO.
2009 Liquid Force Jett 136 Wakeboard
Amber's wakeboard is our most aggressive women's shape, designed for the rider looking to edge, pop and fly more explosively than they ever have. If you're looking to take your riding to the highest levels, the Jett is the perfect 3-stage ticket to fun!
Product Features Jett 136 Wakeboard:
Three stage, hybrid rocker - Straighter curve through center with accelerated kick out the tips -- smooth transitions into the tail section for a higher trajectory off the wakes.
DISC hull - Double inside single Concave - softens landings and maintains board speed.
Double Concave V Tail - Controlled water flow through ends for extra thrust and lift.
Variable Edge Rail - Rolled edge through midsection becoming sharper as it moves towards the tips - forgiving, catch-free through middle, hard cutting and fast off the tail.
Molded-in Deep, Canted long based side fins - Unbelievable hold with large inside face of the fins while maintaining a low outside profile for no hang-ups.
Winged Rail Shape - Side bite slots for extra bite in the flats and quicker release off the wake.
Product Specs:
Length (cm): 136.8 cm
Width (cm): 42.5 cm
Rocker (cm): 5.7 cm
Length (in): 53.9 in.
Rocker (in): 2.3 in.
Rocker Type: 3 Stage Progressive
Stance Range (cm): 50.8 - 61.0 cm
Stance Range (in): 20.0- 24.0in.
Rider Weight (lbs): 100 - 180 lbs
Rider Weight (kg): 45 - 82 kg
Center Fin: XLC 0.8 inch
Side Fins: Molded In Deep Canted
List Price: $299.99
Flex Level 6-8
IP6 Chassis
Impact EVA
EVA footbed
Contact Liner
Articulating Cuff
Velcro Zone System
MSRP: $299.99 USD
