I have a 1989 supra saltare with the Pcm 351 in it I just cleaned and rebuilt the carb because my accelerator pump was not pumping the needed gas and put it in the water to test it and now the engine is bogging down. I thought it was the fuel filter so replaced that and it ran well for a short period of time maybe an hour or so with no issues then when trying to increase the throttle it bogs down and can choke out. Thought it might be water in the gas so dumped in a bottle of heet and another new filter but same result drove around for 15 min fine then it started to bog down and then u couldn't go faster then an idle in gear with out it wanting to die. What really confuses me is that it runs great in neutral and never chokes or bogs in reverse and so I'm confused if it was gas wouldn't reverse be affected or does it only use a limited amount of gas in reverse so the restriction of gas doesn't affect it. Anyone that can help would be appreciated I am about to bring it to a shop cause idk what to do
