i have an '88 sunsport and am in CT, so pretty much the same winter that you have. it's stored outside as well, so that's about the coldest you can get on the engine internals. i've done the following for the past 5 seasons without any issue.
1. fill the gas tank full and put stabil in it.
2. let the motor run to operating temperature on hose water. take off the spark arrestor once the motor has warmed up, to prep for fogging. bucket method works best for running the motor, rather than a fake-a-lake because of the next step.
3. have a bucket with 5 gallons of RV antifreeze ready to run through the motor. side note: i replace the impeller every spring, so i also run the motor for ~15-30 seconds with no water to absorb any moisture in the system (some people do that, some don't). run the RV AF through the motor until it comes out the rear exhaust ports. this will probably only take 2-3 gallons before it runs out of the back, but might as well run all 5 to be sure.
4. once you are down to a gallon or so remaining of AF, spray fogging oil into the carb on both sides. spray a little at a time to make sure it gets in all 4 barrels without stalling, then soak it with fogging oil down the carb until the motor stalls.
5. drain old oil while the motor is still warm. you don't want to leave used oil in there all winter as it is more acidic once used.
6. replace oil filter, re-fill with fresh oil to proper level.
7. crank motor for a few seconds with the coil wire removed, to circulate new oil.
8. spray fogging oil on moving parts/cables, i.e. carb linkage.
9. loosen alternator and raw water pump belts until they are slack.
10. pull batteries.
i also get a few buckets of damp-rid and put one up front, two in the back to absorb any moisture in the boat while sitting over the winter. some people put dryer sheets around the boat to do the same. might be a good idea to use a wet-vac on the carpets to get any excess moisture out, if your carpet isn't excessively dry when you are wrapping it for the winter. i also pull all the seat cushions and store them somewhere dry, to let everything air out over the winter.
'88 Sunsport, 2250lbs ballast, automated surf system, home made surf exhaust, surf flap, ACME 913, Krypt 6.5 HLCD's, Perfect Pass Stargazer
2007 Centurion Typhoon to be upgraded this winter!
