Results 1 to 8 of 8
    Apr 2016
    Johannesburg, South Africa
    Default NOS Gauges for 1991 Conbrio
    Hi All
    Have just bought a 1991 Supra Conbrio.
    Boat is in great nic, but some of the glass on the gauges is damaged, there are cracks on the speedos from the Hot African sun, the volt metre has a cracked glass.
    I have had a scratch around, but there doesn't seem to be anyone selling gauges, so was wondering if any of you know of some NOS kit lying around for a classic Supra.
    Any help would be much appreciated.
    Regards
    Darryl
    Oct 2012
    Guelph Ontario
    Not sure which gauges you have on your Conbrio, but I have an 84 rider with plastic body and bezel gauges and I had to pull the tach apart to replace the trim pot. In my case I just carefully got in behind the bezel with a small screw driver and popped the bezel off. I'm sure you should be able to find someone who does glass who could cut you new pieces once you got them out.
    Apr 2010
    African sun?
    Apr 2016
    Quote Originally Posted by gnarlydude View Post
    African sun?
    Yea live in South Africa
    Apr 2010
    You've got to be the only guy on the continent with one of those... That's rad!
    Apr 2016
    Apologies for the late reply, apparently there is another one close by in pieces, but battling to get hold of the estate, as the owner was kill in a motorcycle accident
    This place sells replacement parts for those gauges:
    http://www.classicboatwork.com/class...e/agr/agr.html
    I've never seen new replacement parts anywhere else, and no matter what it's expensive. But they do have replacement bezels and everything.
    If you can find a junk / used / parted-out boat with old ones that are in good shape, that's always a cheaper way if it's possible.
    Apr 2016
    Yea got new lenses from Dean already, great service, all the way to South Africa!!!!
