My trim all of a sudden will not go up or down, any suggestions? 2007 supra 22 ssv launch
check the hydraulic fluid level. check for power to switch. check power to pump.
Function before fashion!
Where is the pump located?
on mine it is located at the transom behind a plastic piece. It is in the starboard locker. And by plastic piece i mean a large divider that separates the transom fiberglass from the locker.
There is nothing there, I wonder if it is under the back middle seat?
Hello
My 2007 Supra Launch 20SSV just started having the same issue. What ended up being the cause of your issue?
Cy
My 2007 SSV is located on the pass-side in the engine compartment. Mounted up high, closest to the bow.
I just put fluid in it.
Thanks I will give it a shot!
