Well, looks like I am in a similar position now. Since the starter is out of my boat I decided to look deeper into the rudder leak tonight. Dropped the rudder and found the shaft pretty severely bent (like 3/8" over the 5-1/2", trig says that's almost 4 deg). I hit something last fall that had me send the prop out for repair, it felt like it hit the rudder too, but I've been ignoring it. I thought, "I've got 2 engineering degrees, grew up in a machine shop and work with metal every day. I can straighten that!" Wrong. The (presumably bronze) tore at the base of the rudder. Had I left it alone and just re-packed the box again I'd be alright... DOH! It was working, I just got in a tinkering mood...
I'll be on the horn with skidim in the morning to possibly amend my starter order to include one of their rudder packages, or at least get some advice. Probably a call directly to Marine Hardware - the OEM for most underwater gear on any inboard, and my research says the manufacturer of the skidim kit. Looks like there are (like the OP here did) less expensive options than skidim. Any experience in this matter is appreciated!
I have access to the machinery and know how to preform a repair of removing the broken shaft, boring a hole and shrink-fitting a replacement to it, but I'm concerned with the thin wall that would be left to hold the rudder. I;ve never been in s boat that lost a rudder st speed, and I'm damn sure it won't be because my repair work!
Korey Morris -
Current: 2018 Moomba Craz
