Results 1 to 5 of 5
    May 2011
    Quote Originally Posted by ssa View Post
    On my 95 Sunsport the access panel in the floor is to hard to slide without loosening the rear seat and engine cover fastners. Mine also has the bilge type panel in the rear locker and I think it was intended for access to the connections on top of the fuel tank though it's not very helpful for that. One the starboard side of the locker mine has a louvered vent panel cut in that helps getting at the fuel filler neck bolts.
    Thanks for the info. It seemed like I would have to loosen the seats, but was hoping there was a better way.
    Jun 2002
    Canton, GA
    vlawncare
    Congratulations on your purchase. I also own a 97 Sunsport, had it since 99. Engine hatch is easy to remove... Pull it out of the boat... There are two screws that hold the rear floor in place. Remove those screws and the floor will come out. The rear sear has a couple of screws in the bottom holding it to the floor. I removed mine years ago and did not put them back in. The seat fits tight within the gelcoat on both side and the the rear cup holders. It lifts out very easily and gives full access to the fuel tank. The rear cover in the ski locker gives you access to the fuel gauge sender. Mine does not have the shower option. I do have the GT-40. What color scheme is yours? Enjoy!!!!
    May 2011
    Quote Originally Posted by ngavchris View Post
    vlawncare
    Thinking about adding a tower to it
