Results 1 to 6 of 6
    Sep 2002
    Shasta Lake, California
    Default Performance Exhaust
    Has anybody upgraded there Exhaust Manifolds to a performance style? Anything like what I'm showing here?
    1984 SUPRA ALLEGRO 454 PCM 330 HP
    14H 14L Michigan Prop
    Sep 2002
    Nobody has done this or thought about it?
    Maybe THIS would solve my exhaust hose overheating issue, or Jetlink's similar issue!!
    How much?
    I think for me personally, I don't long for more power in the boat - especially since upgrading the engine to the GT-40 - and I spend very little time looking at the engine these days, thankfully!
    Oyama, B C , Canada
    Quote Originally Posted by SUPRA_ALLEGRO_LANE View Post
    Why, other than supposed power increase would you want to do this?
    You have a rare supra classic.
    IMHO to make such change would take away from that.
    NJ
    I have considered it. The factory manifolds are fairly restrictive, though nowhere near as restrictive as older log and snail manifolds. There are also potential weight savings. Stainless is available and will last far longer if boating in salt or brackish water. This does not detract from the value of the boat, it's a bolt on part that replaces a wear item.
    Critical consideration is width. Most performance exhausts will be wider than factory. You don't have much room to work with. Measure the factory exhaust width (about 31" IIRC) and measure the doghouse width. Go from there. Personally for the significant cost ($2500-ish typically) I would only upgrade if my manifolds were rusted bad or already failed. $2500 will get you a lot more power if you put it into the engine, but putting it in the exhaust will only give a marginal performance improvement on an otherwise stock low output marine engine.
    Sep 2014
    I have been thinking about doing this. My reasoning is I want to weld a bung in so I can really dial in my carb with a wide band o2. Stainless would be much easier to work with than the cast iron
