looking for a replacement boat pin for the supra conbrio 1989...any suggestions?
What is a door pin?
Boat pin?Originally Posted by [email protected]
Door pin?
Regardless of which one pls descibe its use or better yet a pic if you have one
The pin for the swing door to the bow. The last owner took it off and cannot not find it. Says he is looking but I don't want to risk not having one , so I am looking for a replacement
I was told this was called a door and not a windshield by the glass manufacturer
At the very least should be able to have one machined for you to fit the hinge.Originally Posted by [email protected]
and where would i do that?
any ideas on where i can get this done? the previous owner cannot find this pin
Can you take a pic of where the missing piece would go?
My boat also has the hinged glass "door" for access to the bow. It doesn't have a pin but a butterfly latch to attach the non hinged side to the fixed windshield when closed.
I would think something similar could be found at a hardware store.
If your has a latch with a loop that a locking pin slides through a machine shop with a metal lathe could fabricate one.
1986 Sunsport Skier with Acme 543
Interesting, that is the hinge pin that is missing.
The hinge is a part of the frame so isn't serviced independently.
That wouldn't be a machine shop item. You could probably find the right gauge wire or rod that would snugly fit.
Before doing that I would call skidim and ask them if they have replacements or any ideas.
http://www.skidim.com/
