You probably need to replace the secondary diaphragm, you are probably only using two of your four barrels in your carb because the vacuum secondary isn't opening. I have the same problem currently and will let you know if the secondary diaphragm fixes it, but it may be a week until I can work on my boat and get it out for a test drive. The secondary is only $15 on Amazon or you can buy a full carb rebuild from O'Reilly auto that comes with it for $60
1986 Supra Sunsport Skier with 351W and swivel spotters seat
