So I got my new motor and trans and v drive mounted in my boat.. How does the cooling lines flow in a 07 21V?
Sent from my LG-H900 using Tapatalk
I'll check mine out this evening. Maybe I can snap some pics if I can get some lighting in it as well.
Rodney
2007 21V - Trailer bunks-*Done
Awesome!
Rodney
Rodney
Rodney
Rodney
I can explain it more if you have a specific question. One of the things you can't see are that the manifolds each have a hose at the rear of the motor, that just ties in together much like the ends of a water hose.
Rodney
From the hull inlet, it goes from one side of the v-drive then out the other to go to the sea water pump on the crank. That is the bottom hose. The top then curls up and goes into that distribution block topside.
Rodney
