Need to purchase a Fresh Water Flush Value for my 24ssv, 2008.
Any POC's, I do not have a dealer near me.
thanks
Rg.
thanks
Rg.
I don't know if I'm off base here but I might have an alternative solution I have a 20 SSV 2008 and I'm using a makeshift (Fake Lake) to do the job.
I went to Lowe's and bought a nine dollar toilet plunger and drilled a little hole in the rubber part to stick a garden hose in and then prop it up under the boat over the water intake for the engine. I was able to wedge it under the boat and it works great
This way you won't have to do any alterations to any holes in the boat.
Jenvey
Sent from my iPad using Tapatalk
My 2008 XLV has a Perko Flush Pro. $80 on Amazon
https://www.amazon.com/Perko-0456DP7.../dp/B00144D86Y
Or you can go to the plumbing store buy a TEE ball valve and a couple of barbed fittings and make your own manual valve:
2004 Mobius LS - hooked on footin'
Former tow: 1986 Chaparral 178 XL, 90hp Merc
First tow: 197x Glasspar Citation, 135hp Merc
Thanks Jenvey. That's where I went wrong... I looked all over the garden section for the fittings and nothing looked like it would pass through a plunger and secure on both sides. I'll look in plumbing next time I'm there.
Both work. The Perko or Valves are pretty slick b/c you connect them and turn the water vs turning on the water and it sprays everywhere. $10 vs $80.
2018 Supra SL400
