Has anyone put a cutler injection unit on PCM 454? The cutler unit has rectangle port intake not sure about the heads (without disassembling) on the PCM 454.
The boat is 88 Mariah
Thanks Tim
Thanks Tim
i don't know but you could call skidim.com, they probably know.
You might look at a Holley Projection TBI setup. It would let you keep your current intake manifold and is a whole lot simpler than MPI.
1992 Supra Mariah - Red
OJ XMP 4 Blade CNC 13x15.5RH
The holly would be an option if buying new but, I have this used cutler already (if it will fit). I called skidim and they said that both retanglar and oval ports heads were availible at the time and were not sure of the external visual clues as to tell which was which.
Thanks Tim
if you need to buy new, edelbrock's bolt up easily and aren't as pricey as new holley. you probably would need to fab a new line though.
