I snapped one of my supports (L bracket) last fall taking off the platform for storage. Anybody have any ideas where to source one? Or should I have one made? Looks to be made out of aluminum.
Thanks,
Kevin
Thanks,
Kevin
Kevin
1993 Supra Sunsport
I have three brackets off my Comp laying around. Which one did you break and what are the dimensions of it? I am there this weekend after picking up the boats so I can take a look again for you.
I broke one of the outer ones, Jet. I don't have the dimensions but they are the same as Trayson's in this link. https://forum.supraboats.com/showthr...Platform-build
Let me know what you have and how much you'd like for it shipped to 54407. Give me a price on one and a price on all 3. Might be good just to snag them all as preventative maintenance!
Thanks!
Kevin
1993 Supra Sunsport
Looks like 15" long and 2" wide. I didn't measure where it bends down to slide into the transom bracket...my guess is 6".
Kevin
1993 Supra Sunsport
Sounds good, I will try and make a run back up to the lake this week or early next week and measure. The center one of my brackets will not work for you, the center one is not as tall on the hull side dimension due to the drain plug being located under it with the low freeboard that the Comp has. I'll measure and see what I come up with.
Kevin
1993 Supra Sunsport
