We just bought our Boat. It is a 02' SUpra Launch SSV. We are still breaking it in but it seems to be slowing down when we turn, when we have the perfect pass on. Any suggestions? Or has anyone here exsperienced the same problem?
When the boat slows down, does the gauge beep and show* by the speed or rpm? If this is significant of your problem, give the boat more than desired throttle, this will let the servomotor have more room to work and hold speeds in your turns. If, by chance this is not the issue, check the troubleshoting section of the manual that came w/the boat, or have a servicing dealer diagnose and repair the problem, it may be a simple program set-up issue. Brian Raymond
I know what you are saying. I can tell you how to fix this. Hit menu 3 times and it will give you speed up speed down. run boat and tune to where the servo meter is tracking..... [email protected] if you have any questions
