Getting a new lift and can't remember what the draft of the Salt is... 26". Maybe 32"?
86 Saltare
26" I believe.
'87 Saltare
I vaguely recall approximating this at 2', or around two of my foot while hanging out in the shallows. 26" sounds right. I'd had mine in some pretty dicey places searching for flat water. Used to run in a spot nobody went to around low tide and seen 1' under the through hull transducer located under the trans plenty of times at the turnaround one end of the straight. Been through a creek with a lock and lots of shallows and no issues. I never dinged a prop, sand don't scare me but rocks and stumps do.
https://crm.skierschoice.com/files/d...ner_manual.pdf
From the manual, it says 25 1/2" so that's a starting point anyway... hence the 26" figure ringing a bell...
