Results 1 to 3 of 3
    Default 2007 sunsport 20v engine problem
    Just purchased 2007 Sunsport 20V and the Center display is not working, any ideas on how to trouble shoot this? Also the engine will only get to 4000 rpms and then bounce between 3800 and 4000. the center display did not work but it just started the hesitation. I have changed the fuel filter, fuel pump, plug wires, plugs, and distributer cap. It is like there is a rev limiter on the engine. Thanks in advance for any help.
    Dec 2013
    I don't know about the gages. For the engine, plug in and read your codes. It'll likely tell you that a sensor is out of range.
    Jun 2011
    College Station, TX
    When you say plugin and read codes, can you use any OBD II port scanner or does Supra / Indmar have a proprietary plug and scanner that needs to be used?
    2007 Supra 24 SSV 340 CAT
    Lake Bryan, TX
