Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Top speed
  1. #11
    Aug 2013
    St. Louis
  2. #12
    Apr 2012
    I just take the hose off the impeller housing. Then i have a old car heater hose that slips onto the housing. On the other end is a plastic hose adapter that you can find at any hardware store.
    Takes only a couple minutes. I used to use a toilet plunger but it never sealed well.
    You cannot run high rpm for long though on land, regardless of any system you use. You cant supply enough water and youll fry the impeller.
  3. #13
    Aug 2013
    St. Louis
    Quote Originally Posted by NorCalPR View Post
    Hadn't thought of this. I almost only run the boat out of the water just before pulling the water pump or just after re-installing it during winterization/summerization. This would be easy and would save a trip under the boat.
  4. #14
    Apr 2002
    Austin
    Another spot to do basically the same as above but easier to reach is removing the hose from the intake side transmission cooler. At least it's easier on the older boats.
