Nice boat. Good stereo. Tower mounted Bimini that removes easily if needed. The drain plug light and interior lights are all on factory switches, no aftermarket switches anywhere. Interior lights are dimmable. Level controls on the dash to adjust the sound independently from the in boat and tower. Can crank the tower and not blast yourself out of the boat. Adjustable sub control also. Converted to electronic ignition last year, no more points. Raw water pump was replaced this year as the bearings were noisy, and I have a spare impeller that's brand new. About 5 hours on the oil change, I only use Rotella and a Motorcraft oil filter. Fuel filter/water separator replaced at the same time, has a Wix on it. Alternator was replaced last August, and upgraded to a 105amp. Battery was replaced last month. I have receipts. Prop is perfect. Tightened the trailer bearings this year, and it has greasable hubs on it. Lights all work, and we're replaced with sealed LEDs last spring. Pulls perfect.
BUDDY of mine was sent this infor about a 92 Supra Mariah with wood stringers. He's asking 9.....thoughts???
