Error Message - Engine #1 | SPN 703 | FMI 3 | Auxiliary Input/Output 3 Circuit
I have a 2010 Launch 24V with the Indmar 340 Assault and only 150hrs. First time in 6 years I've ever seen an error message come on. We were running wide open across the lake (smooth water) for about 15 minutes and the power died and I got this message on the VISION screen ** Engine #1 | SPN 703 | FMI 3 | Auxiliary Input/Output 3 Circuit **. It's like the boat went into limp mode and would only do about 20 mph. After idling a minute I tried again and it was fine. On the return trip to the dock same thing happened after about 15 minutes of running pretty close to wide open. All temps were good, has a fresh oil change, V-drive is topped off. Only thing I did not check was trans fluid. Just wondering what the code relates to?? If anyone has seen it before ?? thanks
- 2010 LAUNCH 24V -
*3,450lbs Ballast (Fly High) *Indmar 340hp *Progressive Tower w/ Swivel Racks *Z5 Cargo *Transom Remote *Pkg F: Tower Speakers, 2 Amps, Light Bar *Dual Battery *Zero Off *Tonneau Covers
