Page 1 of 3 123 LastLast
Results 1 to 10 of 22
    Nov 2015
    Barrington, IL
    Default Please help! Been fighting with my supra for 2 years!
    Alright everyone. I'll give you the smallest run down I can on my issues. It has for the most part been with Idle and starting.
    I purchased my 86 comp 2 years ago and got a hell of a deal knowing a few small things were wrong mostly cosmetic. Ran the boat for the first part of the summer last year and ran ok. Midway through summer everything started going wrong.
    Driving after/pulling a skier at under WOT and randomly would die.
    Not a big deal try and start her back up and no start. Try feathering the gas and get her limping back to the dock. Multiple times having starting issues and attempts at leaving the dock have failed. Thinking it was a carb issue was planning to replace the edelbrock 1409 carb the next year. I tried replacing the first fuel filter attached to the stringer in the bilge. Nothing looked clogged or dirty. Pulled the boat out of the water for the winter and winterized.
    This spring I un-winterized the best I could and could not get the boat started for the life of me. I pulled the dizzy cap and replaced with the ignitor II electronic ignition, new spark plugs correctly gap, new coil 45k volt coil from pertronix, new cap. Before I replaced everything I was not getting any spark. Now I get spark but it is extremely hard starting the boat. Hot or cold... now I can get the boat started if I crank it and give it all the throttle I can in neutral. It idles horrible if I let off the throttle, and it dies almost immediately especially if I have to put the boat in gear. I have to feather the gas and quickly put it in gear and hope it doesn't die.
    Got frustrated and ordered a new 1409 edelbrock thinking that it was just a dirty carb and I would have an extra if I rebuild the old one. But it still runs like crap! Still hard starting and will not idle below 1000 rpms. Again it idles amazingly over 1200rpms. I checked the fuel pressure at the pump and it was around 5.2psi which I believe is normal. My edelbrock says no fuel pressure over 6.5.... I can not for the life of me figure this out. Please help
    1986 Supra comp Ts6m
    Ford pcm 351
    I replaced
    New 1409 edelbrock carb
    New autologhts 24s gapped to .035.
    New cap
    New rotor
    Electronic ignition
    New coil
    New water/fuel filer
    New inline fuel filter right by the carb
    New batteries
    Apr 2002
    Austin
    Starting and idling issues suck! Can't help as I've never done the electronic ignition conversion but ballast resistor issues come to mind and/or maybe timing.
    Lots of peeps here can help so sit tight.
    Welcome to the board.
    Nov 2015
    Barrington, IL
    I upgraded to an electronic ignition that clearly stated taking out the ballast resistor. Pertronix ignitor II. Timing was roughly 10. When I checked it. But that was at 1000+rpm any lower and we couldn't get it running.
    Has the compression been tested?
    Fresh fuel or are you certain the fuel is ok?
    Is your engine at an angle tipped to the rear or is it level?
    Aug 2012
    Wolcottville, IN
    I vote for a timing issue. Did you just replace the Dist Cap or the whole dist? When I bought my salt it would start but then wouldn't run unless it idled at 1500 rpm. thought it was the carb and I changed out the Holley for an Edelbrock but still didn't fix it. Ended up one of the springs on the dist was bad or broke... was not advancing as it should have. replaced the whole distributor with a:
    PNX-D200800
    Distributor, Marine, Plug and Play, Magnetic, Mechanical Advance, Black Cap, Chevy, Big/Small Block, Each
    (Mfr. #: D200800)
    Ran like a champ after that.
    If you can take your distributor apart check for any broken or bad springs.
    What is your timing set at?
    86 Saltare
    Nov 2015
    Barrington, IL
    Quote Originally Posted by jasun View Post
    PNX-D200800
    (Mfr. #: D200800)
    Myself and a buddy got our hands on a timing light and checked and had it set at around 10. This sounds mostly like my whole problem. When I installed the EI I looked in the bottom of the distributer and it was rusty and looked a tad dirty but I didn't see those 2 springs broken at the bottom. Again we didn't replace the whole dizzy, just new cap, rotor that came with the EI and plugs. I am going out of town till the 23rd, and the lakes and rivers on the chain o lakes here in Antioch IL are at record highs. 100 year flood they are saying. Hopefully when I get back into town I can pull the cap off and look at the dizzy more in depth.
    Nov 2015
    Barrington, IL
    PNX-D200800
    (Mfr. #: D200800)
    This is that the dizzy looks like on the inside. No broken springs... one is rusty but when I push it open they spring back to normal...
    N.W. Suburbs Chicago, IL
    Quote Originally Posted by 86ts6m View Post
    I am hoping to get to mine and address a rough idle and overall lackluster performance on my Comp this weekend. Ditching the points and going electronic, kit is already in hand, just need to install and get it going.
    Nov 2015
    Barrington, IL
    The engine is level when it sits in the water. Only angled slightly if that.
