Dose any know where the locational of Manifold System?
I think central bag Valve Solenoid is out. Want redo the system late. Pic will help alot
Look on top of your v drive. Giving the year and model tends to get you more detailed info.
2003 Supra Launch 22SSV
1986 Ski Natique 2001
Supra 2006 Launch 21V
See above...
If you have one, it will be really hard to miss. 3 green round sprinkler valves attached to the lines going to the three bags. The whole manifold sits right on top of the v-drive, when you remove the cover under the back seat - it will be right there.
Lloyd
thx for the help
Verify the fuse to the valve. (Ours is located under the dash). You can swap one that works with one that doesn't and see if that debugs the issue.
2004 Supra Launch 22 SSV
5.7L Indmar Assault
"One More Hour"
I try the fuse first then go for there.Can sweep the sprinkler valves and put in 1" electric ball valves?
A handful of people have done this. I have a couple motorized ball valves for sale if you're interested.
https://forum.moomba.com/showthread....ed-Ball-Valves
Verify you have power to the valve first the switch them out for motorized, self closing 12 volt valves. I just did mine and cut the fill time of a 750lb bag down to a touch over seven minutes. Wish I would have done it years ago. Amazon, US Solid is the manufacturer. 44 bucks a piece.
