Results 1 to 10 of 14
    Default 1984 COMP TS6M Stringer Rebuild
    I am doing this because the People at Photobucket thought it would be a good idea to delete all the photos I have posted over the years unless I pay them 400.00 a year NOT.
    I looked at the copied files I have and I have most of them. I bought the 84 comp about 4 years ago . I was told it had new stringers 6 years before. Here is what it looked like after a through clean up. As you can see it cleaned up pretty good and after a hand full of small mechanical issues we were in business.
    Aug 2016
    Awesome keep em common it was amazing
    After the first season I noticed some oil in the bilge and decided to pull the engine and reseal it . While I had it out I thought I would go ahead and replace the carpet. It was after the carpet was removed I started to see the professional stringer and floor job wasn't so professional. I suspected something was not right because it felt loose when going over wakes and the center pylon was loose. The floor was made out of 3/4 inch plywood it is supposed to be 5/8 and the cap was never removed they just cut out the center section of the floor and spliced in the new plywood. There was no way I could let this go so I pulled the floor.
    After the floor was removed the real fun began. They never replaced the stringers they only sistered a 2x6 pine board next to the rotted stringer and screwed it in from the side. They did however cover it all with glass mat and resin. then it looked like they used spray foam form a can to cover up this mess. At this point depression set in the thought of spiting the hull and redoing the stringers was just TOO much.I thought maybe I could get away with just patching them in and putting in a new floor. I called it a day and went in to think about it. I don't know what I was thinking there was no way I was going to do a Half a$$ job on my boat.
    After the cap was removed and the foam was gone I starter to see the real extent of the damage . White pine is not a good choice for stringer repair. The original stringers were made out of 2 pieces of 5/8 plywood set along side of each other they weren't even connected to each other or the hull except by the fiberglass mat rap .
    The more I removed the worse it got the engine box where the motor sits was especially rotted.
    Once the old stringers were gone and the hundreds of measurements were taken the new stringers could be started. I went with fur 2x6 and 2x8 for the primary and secondary stringers.
    It was quite a job to get them to fit the hull as it twists from angle in the front to flat in the back. I epoxied the stringers to the hull and came back later with a fiberglass resin and powder
    mixture the consistency of peanut butter to make the transition from stringer to hull . Its the brown material . I also put in three holes along the bottom of each stringer to allow any trapped water to get to the bilge .
    Supra puts slots in the top of the stringers so they can put in a 1x2 across the stringers to support the floor. All that did was make a place for water to get in and rot the stringer. I went with a Correct Craft style using a grid system of bulkheads all are epoxied to the hull and stringers. Much stronger and stiffer than the original system.
