Help 1988 Supra Sunsport won't start
Bought the boat in the Spring, worked great all summer. The last day we took it out we had been driving around for awhile. We were moving along and I throttled down quickly and it died and wouldn't start back up. The starter was cranking but wouldn't turn over. The previous owner put a new distributor and Flame Thrower ignition coil. I'm not getting a spark at the plugs. I've tested the ignition coil and shows the proper ohms, it's spraying gas in the carb, battery is good, it's in neutral. I'm learning to be a mechanic as I go. Any thoughts would be much appreciated.
Check the points and rotor. If the screw that adjusts the points gets loose, they get far apart and no spark.
