Throw away the mdc. Here is my thread, Same boat.
https://forum.supraboats.com/showthr...head-questions
Function before fashion!
Definitely going to change the gauges out and get rid of mdc thanks for all the info. In hope to fix issues I put new fuel pumps on and new filters. Problem still exist. I didn’t get a chance to get a fuel pressure gauge but I have a entirely new fuel system and new relay. It’s all not a over heat problem that I can tell cause it never gets over 160, but I do believe it’s going into limp mode. Which scan tool can I get to view the codes?
99 santera
Also in checking every thing out I found that the warning light for the v-drive oil pressure wasn’t hooked up. Now that it’s connected the light never goes off. The gearbox has the right amount of oil. The oil looks and smells good, and doesn’t get hot to the touch. There are no problems or noises from any thing. Could the pressure switch be out?
99 santera
Gotta love PO's! Yes, it is very likely the pressure switch is bad, as the V-drive itself is almost indestructible. Your last owner likely disconnected the light rather than actually fix something!?!
I finally got some spare time to hook the rinda up to the boat. The only fault code is engine over heat. Unless it was a quick spike when is was not watching, it never got hot. Now that I have the diagnostic tool I’ll go out on the lake and recreate the problem with the scanner hooked up to see if it’s actually over heating. If it’s overheating what is the first step( water strainer clean, can’t see any debris in intake) could it be sensor, impeller, water pump. Thanks for all your help
99 santera
It sounds like you've got a lot going on. If you know you have sufficient fuel pressure to the injectors, then the problem must be ignition. I don't think overheating will cause it to sputter . . but then again, my boat doesn't have all of the electronics on the motor. Did you check the distributor cap? The problem you describe in the beginning sounds an awful lot like what my boat does when it gets condensation in the distributor cap.
C Suggs
Well I finally got around to going back to the lake. Changes temp sending unit and tps just to rule that out. I hooked up the rhinda while I was running and found that the engine is overheating or at least thinks it is. The gauge on the dash seems to be working cause if I run hard then shut down it heats up a little but instantly cools off when started. Computer on the other hand seems to think it’s getting up to 215 while pulling at load and puts me into limp mode but slowly cools back down and runs good again until it over heats. I know there are two different sensors for temp but why would they be reading so different?
99 santera
I have the same model with similar problems this year. My temp gauge was reading 160 as well. So I thought I had water in the gas. I changed fuel filters twice and put water treatment in the fuel. Then I changed the raw water pump and thermostat and it seams to have taken care of it. Only had it out for an hour or so. Where did you get your scan tool? Just FYI my transmission switch was never wired either. I bought my boat when it was about 3 years old.
