Ordered my SL without it because it wouldn’t be strong/bright enough in our lake due to water quality. Surprisingly switch is hooked up and command center is showing solid/strobe function available.
Installed led light but would like to tie it into existing wiring instead of using one of the accessories switches if possible.
Tracing today didn’t do much. Found one set of wires on the right side just ending at the top rear ballast pump and a deutsch connector on the left side just below the cup holder near the surf locker. It it was a 4 pin one ... which wouldn’t make much sense. Has anybody by chance seen where the wire for the transom led is hooked in during oil change or similar (you need to take the rear plastic panels out inside the surf locker to see it FYI
I’ll ask dealer tomorrow too but maybe someone has tried this already and is ahead of me
