Two thousand supra fuel pump not getting power.. works with external power is applied any suggestions ?
The pump is working.. there for, it’s something from the battery back to the pump. Try checking the relay and fuse. Also, any switch it could be possibley wired into.
What Thor said . In my pic you can see the three mini fuses. One of them might be burnt out. Beside this fuse holder there are 3 relays. The one with the green/white wire is the fuel pump relay. Might have to replace it. The mini fuse was my problem.
My boat is a 2000 supra does not have fused as shown in picture .wonder if they could be somewheres else?
Study my picture. Look at back of the engine. What looks like a plug of sorts is a cover and holder of 3 fuses. The relays are the big guys at the back of the engine. Mine are attached to a black plate.
I have a 2002 supra launch dd. They should be the same.
