Results 1 to 4 of 4
Thread: 2000 Legacy
    Apr 2003
    Default 2000 Legacy
    I am having a hard time with water collecting in my engine compartment. I did not even realize my boat had an automatic bilge but I was told it does. Could it be that the bilge button has a setting that disengages the automatic bilge? I know it has 3 settings so I'm thinking maybe it's disconnected, b/c it is definitely not working. Thanks.
    [email protected])
    Aug 2002
    Tn.
    Default Auto bilge no worky
    Call your local dealer and set an appt. to have the issue looked at and rendered. If this is not a feasable option, contact [email protected]. They will be able to assist you with troubleshooting steps, and wiring diagrams. Have you checked your shaft log adjustment? Brian Raymond
    I have the same problem in my 1990 Supra Comp. Auto Bilge does not work at all. Regular bilge works fine.
    Have not had a chance to troubleshoot yet. Didn't know there was 3 choices for mode of operation. I just have two switches for Bilge 1 (Manual) and Bilge 2 (Auto).
    Kevin
    May 2003
    Buda and Horseshoe Bay, TX
    Default More Bilge
    My '98 Comp is somewhat "iffy" in bilge operation, but I think the problem is float sticking because of oily crud floating in engine compartment from previous owner (I am working on it!). It has been known to stick in the "on" position.
    Anyway, besides the two positions on the dash, it also has a switch on the bilge float which I think locks out the auto position.
    If worse comes to worse, automatic bilge pumps are not that expensive, but the factory unit looks like a good piece of equipment.
    Nick Stoffel
    98 Supra Comp w/b
