Results 1 to 6 of 6
    Guest
    Default Stuffing Box Adjustment
    Can someone help me out with how i go about adjusting my stuffing box? I have a 1985 supra comp ts6m. I've never adjusted one before and would like a little guidance before attempting it. Thanks for any info
    I have a 90 Comp.
    What I did -
    Loosen up the thinner nut on the prop shaft. It will go back towards the bottom of the boat.
    Tighten the larger end bolt until you only get about 1 drip every 5-10 seconds into the boat. I did this while the boat was running and someone else was driving. Just be real careful. Not sure if there is a safer "recommended" way.
    Retighten the thinner bolt back up.
    I am sure these bolts have more techincal names - but I just did it for the first time on Saturday.
    Kevin
    Apr 2003
    Wisconsin
    Thanks I'll try that this week hopefully or this weekend. There doesn't seem to be a good way to do it without being in the water. Oh well. Thanks for your input I appreciate it.
    Apr 2002
    Austin
    yup, you need to be on the water to make sure you get a slow drip of water to keep it lubed.
    Apr 2003
    Wisconsin
    Can it just be sitting in the water or do you have to be driving/running it?
    It was my understanding it has to be going to adjust properly. I had someone else drive while I adjusted. Just be real careful of the tranny.
    Kevin
