Results 1 to 6 of 6
Thread: Oil change
    Oct 2018
    Default Oil change
    I have a 03 santera and will be changing my oil here soon....wondering what oil And filter I should go with. This would be the first oil change I do as this is my first boat. Any and all help is much appreciated. And tips and tricks is also helpful. Thanks in advance
    What engine does it have?
    Oct 2018
    Not 100% sure but I believe it’s the indmar assualt
    GM or Ford?
    Apr 2002
    Florence, AL
    Speaking in generalities, Wix makes a good filter for a fair price. After several oil analyses on my PCM Ford 351, I settled on Shell Rotella T6 5W-40. It's a diesel oil, but it can stand up to the shear, fuel dilution, and abuse a gas marine motor dishes out. I personally avoid any 5W-30 or 10W-30 automotive oils in marine inboards.
    1992 Supra Mariah - Red
    OJ XMP 4 Blade CNC 13x15.5RH
    15-40 rotella or delo. Change it every year. I usually go two changes to one high quality filter. (I run about 50 hours a year, not enough to come close to using up the filter media)
    Marine engines run hot oil temps and heavy loads. I wouldn't run anything less than a 10-40 in the motor. Seems like almost every manuf agrees as well
