Originally Posted by NorCalPR Neutral position switch on the trans. Try jiggling the shifter forward or reverse when trying to start. You may need to adjust the cable, or replace the switch. Sent from my SM-G920V using Tapatalk Agreed, a new switch with an improperly adjusted transmission cable will not solve the problem so don't skip this step.
87 Saltare rebuild pics: http://supraboats.com/bbs/showthread...altare+rebuild
Thanks Guys for your help I installed a new neutral switch on the transmission and that appears to do it. All good for now. Now get out and ski !!!
