Results 1 to 3 of 3
    May 2019
    Default 2015 SE Gauges will work for a little while them quit.
    My gauges will work analog and digital and then they will quit. The boat will still run, but you canít use any of the functions. The analog and digital will all quit at the same time. If you key cycle it. the analog gauges will do the normal startup but wonít work after that. Any help would be great. Thanks. New to the forum and Supra boats
    Jul 2015
    I have had the same issues among a few others on my 2015 as well. I did some research and had them re-flash the software. I am being told that that will fix the problem but have not had the chance to test it as the weather has been bad where I am. If you do the same make sure and take pictures of all of the setting as they will be erased. Hop this helps
    May 2019
    Have you had a chance to see if the software flash fixed your boat?
