Results 1 to 2 of 2
Thread: Running issues
    Oct 2018
    Default Running issues
    So Memorial Day weekend we made it out to the lake.....only the fun lasted about 30 minutes before I lost power to the boat and had to be towed back in. Figured it out and repacked the ignition coil as we were getting no spark. Was able to start right up. Now a couple weeks later was able to get it out on the lake again...and the exact same thing happened. Havenít been able to check yet but it seems itís the same issue again. Only we had only been on the lake for maybe 10 minutes....boat loses power and is acting up under very little load. Killed the boat and it would never start up again. Will be able to get home after work today and start checking on things but itís the exact same issue. Is there a reason the ignition coil would go out again or would something be causing that?
    Jul 2007
    Flowery Branch Georgia
    What year and ignition do you have ?
