Results 1 to 5 of 5
    May 2018
    Default Velvet Drive Trans Issue- Please help
    Major issue and I have a trip coming up, and the Supra Reunion. Losing all trans fluid when starting engine. Trans cooler and lines are all new and just replaced. Cannot see or feel any fluid, but you pour it in, start the boat and put in gear, you'll see it in the bottom of the boat within a minute. All of it. 1987 Supra Mariah with PCM 351 and Borg Warner Velvet Drive 1:1 trans.
    Anyone? I am guessing maybe the gasket between the trans and the engine? Any help is appreciated.
    Splbuilder
    1987 Supra Mariah
    Apr 2009
    SE MICHIGAN
    there is no gasket between the trans and the engine most likely the front pump seal
    1986 TSM6
    1987 SALTERA
    May 2018
    Ordered the front seal from SkiDim. Going to try to separate the trans from the engine tonight. Don't really know what I'm doing but I'll give it hell.
    Splbuilder
    1987 Supra Mariah
    Aug 2013
    St. Louis
    There are some threads here on rebuilding. Should you decide to have someone else rebuild it, http://fantasticfinishmarine.net/ just did a nice job on mine.
    Feb 2014
    Clayton NC
    Here is a link I made for removing my transmission with a link to another good thread https://forum.supraboats.com/showthr...te+replacement
    Good luck with the repair. It can be challenging getting good access to all the connections to remove the transmission. I think I ended up having to cut one of my wrenches in half to get to one bolt
