Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 48
  1. #21
    May 2019
    Arizona
    Yes. Ordered through my local dealer. They color match it to your boat. There are a few options you can buy, SS trim rail, seadek pad, etc. Used the same brackets. I think mine was $1000-1100
    So I’ve been observing what my swim platform is doing with the surf wave. What I’m noticing is water is cutting across the aft rear corner of the platform. I’m wondering what effect this has on my wave. I’m noticing the first part of the wave doesn’t have a defined lip. Is this rounding of the first part of the wave caused by the swim platform?
  2. #22
    I would assume so. The newer platforms are not as wide. You can see how the water comes off the bottom of the boat with the red line. Granted, this is a newer boat.
  3. #23
    Another view - high flyer.
  4. #24
    Aug 2019
    Before I buy a new style platform I was going to make a "2" lift kit" for my current platform in the Spring with pieces of square aluminum tubing and longer screws. Has anyone tried this "redneck" solution??
  5. #25
    May 2019
    Arizona
    Quote Originally Posted by Hanso24V View Post
    I saw a 07 Supra with the new style swim platform as well as the new style brackets and when they mounted the brackets they just mounted them higher. I’m going to do mine this way since I really don’t like the design of the old brackets.
  6. #26
    Default 2005 24SSV surf ballast set up
    2” will raise that high w/o ballast.
    My 22 with my surf platform and a 3/4” raise. Next to my buddy’s 24
  7. #27
  8. #28
    May 2019
    Arizona
    What’s that piece of aluminum running from your swim bracket?
  9. #29
    Aftermarket FAE exhaust support.
  10. #30
