oil leak
91 supra comp
ford 351 pcm
I have an oil leak on my motor, coming from the rear of the inlet manifold at the join between the manifold and the engine block, right behind the electric circuit breaker. This has been fixed once by the previous owner but obviously not very well !!
My questions are, what gaskets/seals are there on the manifold , presumably i will need to remove the manifold and replace the gaskets seals etc.
Is there a particular "trick" to getting it right, and should i use any sealents on the gasket/s. What are the torque settings for the manifold bolts ?
Any other tips or advice would be gratefully received as this is really messy problem.
PS the sun is shining over here and the water is GREAT !!!
Nick H
Oil leak
The original gasket set and proper torque specs. can be found by contacting Vince at Discount Inboard marine, email; www.skidim.com, or call (803)345-0096.Brian Raymond
Hi,
Vince will help you out. I just got the valve cover gaskets and exhaust manifold gaskets from him for my 90 Comp PCM 351. He will know everything that you will need and their prices are great.
Kevin
