Results 1 to 5 of 5
    Aug 2019
    Default 2008 Supra Launch 21V Drain Question
    Hi. We are the proud new owners of a 2008 Supra Launch 21V. It is our first boat and we are thrilled with it. It has about 450 hours on it and has run perfectly all summer. I do have one question though. When I remove the drain plug on the back of the boat the water that drains out has a little bit of oil in it. I have just assumed that there might have been a little oil in there from an event of the past owner because it is an 11 year old boat and over time there could have been a little oil in the area that the drain plug on the back drains. It is not enough to discolor the water, however when it drains I can see the a little of the oil in water color on the ground. There is no oil in the water that is pumped out of the bilge pump. Also, there is no current loss of oil. Any help would be great. Thanks.
    Could be from a bad oil change?
    Could be a little leaking from the motor somewhere. But you said you are not low on oil.
    If you trailer the boat, get some Dawn Soap and a garden hose down there. You should be able to get under the motor with a sponge or small brush to clean real good.
    Then just tilt it back and most all water should rain out. I've used a floor jack to help it tilt.
    Plus that old dirty water can get smelly down there.
    Oct 2008
    Northern Colorado
    I have had it leak from around my oil
    Filter a few times. Makes a heck of a mess, and man does it get
    Smelly!
    Starbrite also makes some bilge cleaners. I have never used it, but reading about it, people like it. Comes in Citrus (orange) too!! Ha Ha. Good marketing idea.
    May 2019
    Arizona
    As my dad always says “ a little oil makes a big mess”. I just put a few drops of Dawn in the bilge before we use the boat.
