Results 1 to 7 of 7
Thread: 1998 Supra Comp
    Oct 2019
    Default 1998 Supra Comp
    I purchased a few weeks ago. Fair to Good condition. Have spent many hours cleaning hull and Cleaner wax above the water line. Interior was covered by a boat cover that leaked over a period of 2 years. Some of the vinyl on the seats has black spots I can't get off...Any suggestions??? I took it out for my First Run yesterday. Top speed was 35mph, Is that normal ? Indmar V-8. I want to restore this boat for my Grandchildren and teach them to ski while I still have my health at 70. Thanks for your consideration folks
    Aug 2010
    Oyama, B C , Canada
    Quote Originally Posted by BillyBrad View Post
    I purchased a few weeks ago. Fair to Good condition. Have spent many hours cleaning hull and Cleaner wax above the water line. Interior was covered by a boat cover that leaked over a period of 2 years. Some of the vinyl on the seats has black spots I can't get off...Any suggestions??? I took it out for my First Run yesterday. Top speed was 35mph, Is that normal ? Indman V-8. Iwant to restore this boat for my Grandchildren and teach them to ski while I still have my health at 70. Thanks for your consideration folks
    Should be able to achieve approx 44 to 45 mph.
    Your engine is an Indmar .
    Oct 2019
    Thank You for the reply....Could it be the prop? Tuning? carb? engine sounds good. Wonder what to check out 1st etc?
    Aug 2010
    Oyama, B C , Canada
    Do a compression test on all eight cylinders first!
    All of your suggestions are valid ones.
    Unless you are a good mechanic take it to a reputable marine shop and let them run through the gauntlet for you.
    Could be a combination of things .
    Good luck!
    Oct 2019
    Thanks Again ….Compression check...Coming UP!!!
    Aug 2010
    Oyama, B C , Canada
    Assuming your compression test checks out ok, then you need to chase the cause for your slow speeds compared to normal.
    You can spend a lot of money chasing potential causes on your own .
    Go to a reputable marine shop and let them do it for you.
    Could actually save you dollars in the long run.
    Oct 2019
    I'm guessing there are a lot of suspects with an issue like this?
