Results 1 to 3 of 3
    Oct 2019
    Default 351 PC Windsor Wiring question
    I’ve installed new carb, new distributor, fuel line, filter and pump, plug wires, plugs, and wiring harness. I think I have it wired up correctly and I have it 8 degrees before TDC. I have the rotor pointed correctly also. However, I cannot understand one thing though; how and where do I connect the red and brown wires That come out of the new connection to the distributor? Can I just ground the brown on the engine block? Should I run the red wire back to the resistor and connect it to the red side of the resistor? The directions are confusing.
    Oct 2019
    Please help me
    What year is the boat? Can you post pictures of the distributor and wiring?
