Results 1 to 10 of 11
    Feb 2013
    Default 1988 ts6m rebuild
    So I have been an observer for the most part over last 6 or 7 years, used to have a 1986 Pirata with my brother but we split up on that 3 years ago. Since then my wife and I bought a 1988 TS6M Comp. Over the years we have replaced the steering cable and added PerfectPass with Zbox upgrade along with a few minor repairs and upgrades. This winter we decided it was time to tackle the floors/stringers. Having owned an old Supra before we have been well aware of the project we were getting ourselves into when we bought the boat. There were two soft spots when we bought it back near the rear seat, so we figured we could get a few good summers out of it before needing to be replaced. So far we have pulled the motor and gotten the cap off. I have tried my best to read through everyone else's rebuild threads on this site and think I have a good idea as to what needs to be done, but who knows what I am getting us into. We have a detached garage that is just barely big enough to do the work in, so hopefully we can work on it a couple nights a week and most all weekends. Hoping to be ready to ski as soon as spring rolls around. I will try to post our progress and pictures as we go.
    I appreciate all of you who have posted your rebuild projects, and am welcome to any pointers or advise.
    Does anyone have advise as far as best way to post pictures, as I have notice a lot of the older posts pictures are no longer available
    I use imgur to post pics. If you are talking about the pics that Photobucket deleted there is a fix from google chrome to recover the pics. You want to use Douglass Fur for the stringers and marine plywood for the floor . I always coat all the wood with clear penetrating epoxy sealer [CPES] FROM THE Rot Doctor web site .
    US Composites is a good place for glass and epoxy.
    Feb 2013
    Thanks for the info, did find out that my local lumber yard has douglass fir in stock. We are working this week to get the stringers on one side cut out, planning to do 1 side at a time so we can mirror the other and make sure the height of stringers all stay consistent. I was able to create an Imgur account and get some pictures of our progress up.
    https://imgur.com/a/ukESQGq
    We were hoping the rot was not as extensive as it. There was a lot of water trapped up in front of the bilge, which made for a nasty day of getting the foam out. Seems like we are making good progress on the demo.
    Once you post pics on Imgur you can put mouse on your name in the upper right corner then click images in the drop down click the picture you want to post click copy on the second from the bottom marked forum then you can paste it to your post. Make sure you edit the size of your pic. I use 1000x2000.
    Quote Originally Posted by 3826smith View Post
    Yeh, imgur or pasteboard.co are good for this.
    My names Joe and im a self employed painter from Melbourne, Australia. If you want to network find me here.
    Feb 2013
    So we have been pretty busy lately and have not been able to put much time into the boat until this past weekend. We were able to get the two stringers on the starboard side cut out and sanded. I found that an oscillating tool with a carbide blade was the best tool for this. Once the stringers were out it is clear how extensive the rot is, especially where the motor mounts were lagged in.
    Once the stringers were out of the way we moved on to the blocking for the swim platform and rear hooks. After going back and forth on whether or not to mess with them I am glad we did. At first when I cut into the blocks the wood seemed in good shape, but once below the waterline it was obvious that some water had penetrated through the wood as it was just starting to rot.
    I still have a bit of sanding to do as the original fiberglass work was very sloppy and inconsistent. Large bubbles in some areas and some spots that almost seem like they did not put any resin on at all.
    Hoping to start fitting the new stringers in this coming week after the holidays. Can someone give me some pointers as to what type of epoxy and fiberglass I should be using and where? This is my wife and I's first time doing any fiberglass work and I am a bit confused as to what to use. Any advice or pointers is appreciated.
    N.W. Suburbs Chicago, IL
    I would call these guys and talk to them about your project. Wealth of knowledge and will help steer you in the right direction.
    http://www.uscomposites.com/
    Riding Connelly Skis
    US Composites are a great source of materials and knowledge for sure. Take lots of pics and measurements it will help when you put it back together.
    May 2009
    Back to Dallas!
    Seeing that brings back nightmares. Lol. Im so glad mine is back together.
    89' Comp rebuild thread:
    89' Comp Mod's and fun pic's:
    Feb 2013
    It has been a while since I have posted any progress. January was rough as the wife and I both caught the bug that was going around so we missed quite a bit of time feeling under the weather makes it tough to find the motivation to go work in a cold garage. February is going well though making some strides and finally feel like we are making forward progress. We were able to get the starboard side stringers formed and fitted to the hull, and after a test run of mixing PB to find a good mix and consistency were able to get them set in place.
    I am happy with how the stringers worked out and keeping the port side stringers in place while doing the starboard really helped to make sure the deck height will stay where is should. Now that starboard stringers are solidly epoxied to the hull I removed the port side stringers, transom backing, and the strut and rudder backing boards. The board over the rudder poured waters when the fiberglass was cut around it, and was able to remove in one piece as it was so rotted. We have a bit more sanding/grinding on the port side which should be done this weekend. Then on to forming and fitting the last two stringers.
    Hopefully we are still on track to be back on the water in May. All the stringers should be in by the end of February, fiberglass the stringers in March and start the decking, and finally reinstall the cap and motor by the end of April.
    Thanks to everyone for the advice it is much appreciated, we are enjoying the project but can't wait for the end result!
